7D micro AF adjust + 24-70 2.8L sharpness?
JCviggen
22 Feb 2010
Hello all, first post :)
A few weeks ago I bought a 7D and a 24-70 2.8L lens.
I've been experimenting quite a bit but the sharpness so far is dissapointing in many pictures, particularly portraits. Even with plenty of shutter speed the faces tend to be very soft.
I considered the lens/body might be front or backfocusing so I started experimenting with the AF micro-adjust function of the camera. To my susprise, the effect of changing the setting appears to be exactly zero. I can set -5, -20, +10 or whatever...the sharpness is not noticably different.
I used the pattern and test method from here as well http://www.northlight-images.co.uk/article_pages/cameras/1ds3_af_micoadjustment.html and still, the micro-adjusts seem to be making no difference.
I did find out that 8/10 times the AF will be correct (as in : impossible to improve with MF) but the sharpness is still only in between focus and out of focus. I could accept this at F2.8 but even at F4 life isn't much better.
Anyone any suggestions? :) I know the 24-70 lenses can be hit or miss, I am getting a 70-200 2.8L IS in about a week from now, then I can compare.
Still, I'm quite puzzled at this point :(
Some RAW files of shooting in the garden can be found here (sharpness is OK compared to portraits here, but especially the tree shots are bad http://www.greenringer.net/various/sharpness/RAW/ )
Cheers
