News Fuji X100V
dirk
CI Gründer
Admin
15 Mai 2002
Heute wird Fuji den Nachfolger der Fuji X100F vorstellen. Die üblichen Gerüchteseiten haben schon viele Informationen veröffentlicht. Bisher ist folgendes bekannt:
Number Of Effective Pixels
26.1 millions pixels
Image Sensor
23.5mm x 15.6mm (APS-C) X-Trans CMOS 4 with primary color filter.
Storage Media
SD memory card (-2GB) / SDHC memory card (-32GB) / SDXC memory card (-512GB) UHS-I*1
File Format Of Still Image
Compliant with Design rule for Camera File system (DCF2.0) JPEG: Exif Ver 2.3
RAW: 14bit RAW (RAF original format) / RAW+JPEG
Number Of Recorded Pixels
L: <3:2> 6240 x4160 / <16:9> 6240 x3512 / <1:1> 4160 x4160 M: <3:2> 4416 x2944 / <16:9> 4416 x2488 / <1:1> 2944 x2944 S: <3:2> 3120 x2080 / <16:9> 3120 x1760 / <1:1> 2080 x2080 Panorama:
L: 2160 x 9600 [Horizontal : 9600 x 1440] M: 2160 x 6400 [Horizontal : 6400 x 1440]
Lens Type
FUJINON single focal length lens
Lens Focal Length
f=23mm (35mm format equivalent : 35mm)
Lens Max.
Aperture F2.0
Lens Configuration
8 elements in 6 groups (includes 2 aspherical elements)
Lens Nd Filter
Yes (4 stops)
Aperture
F2 – F16 1/3EV step (controlled with 9-blade aperture diaphragm)
Focus Range
Approx. 10cm to infinity / 3.9in. to infinity
Conversion Lens
WIDE / TELE / OFF
Digital Tele-Converter
35mm (Nomal), 50mm, 70mm, 35mm fomat equivalent
Sensitivity Standard Output
AUTO1 / AUTO2 / AUTO3 / ISO160-12800 (1/3EV step)
Sensitivity Extended Output
ISO80 / 100 / 125 / 25600 / 51200
Exposure Control
TTL 256-zone metering, Multi / Spot / Average/ Center Weighted
Exposure Mode
P (Program AE) / A (Aperture Priority AE) / S (Shutter Speed Priority AE) / M (Manual Exposure)
Exposure Compensation
-5.0EV-+5.0EV 1/3EV step (Movie: -2.0EV-+2.0EV)
Shutter Type
Lens Shutter
Shutter Speed
Mechanical Shutter:
P mode: 4sec. to 1/4000sec
A mode: 30sec. to 1/4000sec, S/M mode: 15min. to 1/4000sec Bulb mode: up to 60min.
Electronic Shutter:
P mode: 4sec. to 1/32000sec
A mode: 30sec. to 1/32000sec, S/M mode: 15min. to 1/32000sec Bulb mode: 1sec. Fixed
Mechanical+Electronic Shutter:
A mode: 30sec. to 1/32000sec, S/M mode: 15min. to 1/32000sec Bulb mode: up to 60min.
Continuous Shooting
Approx. 11fps (JPEG: 38 frames, Lossless compression RAW: 17 frames, Uncompressed RAW: 17 frames)
Approx. 8.0fps (JPEG: 76 frames, Lossless compression RAW: 18 frames, Uncompressed RAW: 18 frames)
Approx. 6.0fps (JPEG: 220 frames, Lossless compression RAW: 21 frames, Uncompressed RAW: 18 frames)
Approx. 5.0fps (JPEG: 458 frames, Lossless compression RAW: 24 frames, Uncompressed RAW: 19 frames)
Continuous Shooting (Contd.)
Approx. 4.0fps (JPEG: endless, Lossless compression RAW: 28 frames, Uncompressed RAW: 20 frames)
Approx. 3.0fps (JPEG: endless, Lossless compression RAW: 34 frames, Uncompressed RAW: 21 frames)
Approx. 30fps [Only electronic shutter, 1.25 x Crop] (JPEG: 29 frames, Lossless compression RAW: 17 frames, Uncompressed RAW: 17 frames)
Continuous Shooting (Contd..)
Approx. 20fps [Only electronic shutter, 1.25 x Crop ] (JPEG: 79 frames, Lossless compression RAW: 17 frames, Uncompressed RAW: 17 frames)
Approx. 20fps [Only electronic shutter] (JPEG: 32 frames, Lossless compression RAW: 17 frames, Uncompressed RAW: 17 frames)
Approx. 10fps [Only electronic shutter, 1.25 x Crop] (JPEG: 153 frames, Lossless compression RAW: 18 frames, Uncompressed RAW: 18 frames)
Continuous Shooting (Contd…)
Approx. 10fps [Only electronic shutter] (JPEG: 81 frames, Lossless compression RAW: 18 frames, Uncompressed RAW: 18 frames)
Approx. 8.0fps [Only electronic shutter, 1.25 x Crop] (JPEG: 90 frames, Lossless compression RAW: 18 frames, Uncompressed RAW: 18 frames)
Recordable frames depends on recording media
Speed of continuous shooting depends on shooting environment and shooting frames Auto Bracketing
AE Bracketing
(Frames: 2, 3, 5, 7, 9 Step: by 1/3EV step, up to +/-3EV steps)
Filmsimulation bracketing (Any 3 types of film simulation selectable) Dynamic Range Bracketing (100%, 200%, 400%)
ISO sensitivity Bracketing ( +/-1/3EV, +/-2/3EV, +/-1EV)
White Balance Bracketing ( +/-1, +/-2, +/-3) Focus Bracketing (AUTO, MANUAL)
Af Mode
Single AF / Continuous AF / MF
Af Type
Intelligent Hybrid AF (TTL contrast AF / TTL phase detection AF)
Af Low-Light Performance Contrast: -2.0EV
Phase Detection: -5.0EV Af Frame Selection
Single point AF: EVF / LCD: 13 x9 / 25 x17 (Changeable size of AF frame) Zone AF: 3 x3 / 5 x5 / 7 x7 from 117 areas on 13 x9 grid
Wide/Tracking AF: (up to 18 area)
White Balance
Automatic Scene recognition / Custom1-3 / Color temperature selection (2500K-10000K) / Preset: Daylight, Shade,
Self-Timer
10sec. / 2sec.
Interval Timer Shooting
Yes (Setting: Interval, Number of shots, Starting time)
Flash
Auto flash [Super Intelligent Flash] Effective range: (ISO 1600) approx. 1.0 – 24.3′ (30cm – 7.4m) Guide Number: approx. 4.4 (ISO100 m)
Flash Mode
TTL MODE (Flash Auto, Standard, Slow Sync.), Manual, Commander, OFF
Flash Sync. Mode
1st Curtain, 2nd Curtain
Flash Red Eye Removal
Flash + Removal, Flash, Removal, Off
Hot Shoe
Yes (Dedicated TTL Flash compatible)
Ovf
Reverse Galilean viewfinder with electronic bright frame display Coverage of frame area v.s. capturing area:
approx. 95%
Magnifications approx x0.52″
Evf
0.5 inch approx. 3.69 millions dots OLED Color Viewfinder (4:3)
Coverage of viewing area vs. capturing area: approx. 100%
Eyepoint: approx. 16.8mm (from the eyepiece lens), Diopter adjustment: -4-+2m-1 Magnification: 0.66 x with 50mm lens (35mm equivalent) at infinity and diopter set to -1m- 1
Diagonal angle of view: approx. 32 Degree (Horizontal angle of view: approx. 27 Degree ) Built-in eye sensor
Lcd Monitor
3.0 inch, aspect ratio 3:2
approx.1.62 millions dots tilting touch screen color LCD monitor(approx. 100% coverage) File Format
Format: MOV, Compression: MPEG-4 AVC/H.264
Audio: Linear PCM / Stereo sound 2ch / 24bit / 48KHz sampling
Movie File Size/Frame Rate/Rec. Time
[DCI 4K (4096 x2160)] 29.97p/25p/24p/23.98p, 200Mbps/100Mbps, up to approx. 10min [4K (3840 x2160)] 29.97p/25p/24p/23.98p, 200Mbps/100Mbps, up to approx. 10min [Full HD (2048 x1080)] 59.94p/50p/29.97p/25p/24p/23.98p, 200Mbps/100Mbps/50Mbps, up to approx. 15min.
[Full HD (1920 x1080)] 59.94p/50p/29.97p/25p/24p/23.98p, 200Mbps/100Mbps/50Mbps,
File Size/Frame Rate/Rec. Time (Contd.)
[Full HD (1920 x1080) High speed rec.] 120p/100p, 200Mbps(recording), up to approx. 6min.
For recording movies, use a SD memory card with UHS Speed Class 3 or higher. Although movie recording will continue without interruption when the file size reaches 4GB, subsequent
Film Simulation Mode
17 modes (PROVIA/Standard, Velvia/Vivid, ASTIA/Soft, Classic Chrome, PRO Neg.Hi, PRO Neg.Std, Black & White, Black & White+Ye Filter, Black & White+R Filter, Black & White+G Filter, Sepia, ACROS, ACROS+Ye Filter, ACROS+R Filter, ACROS+G Filter, ETERNA/Cinema, Classic Neg) Monochromatic Color
Clarity Setting +/-5 steps
Hdr Mode
AUTO, 200%, 400%, 800%, PLUS
Grain Effect
Roughness: Strong, Weak, Off / Size: Large, Small
Color Chrome Effect Strong, Weak, Off
Color Chrome Blue Strong, Weak, Off
Dynamic Range Setting
Still: AUTO, 100%, 200%, 400%
ISO restriction (DR100%: No limit, DR200%: ISO320 or more, DR400%: ISO640 or more) Movie: 100%, 200%, 400%
Advanced Filter
Toy camera, Miniature, Pop color, High-key, Low-key, Dynamic tone, Soft focus, Partial color (Red / Orange / Yellow / Green / Blue / Purple)
Wireless Transmitter
Standard Access Mode: Infrastructure
Wireless Transmitter Standard
IEEE802.11b/g/n (standard wireless protocol)
Wireless Transmitter Standard Encryption WEP / WPA / WPA2 mixed mode
Bluetooth Standard
Bluetooth Ver 4.2 (Bluetooth low energy)
Bluetooth Operating Frequency
2402 – 2480MHz (Center Frequency)
Terminal Digital Interface
USB Type-C (USB3.1 Gen1)
Terminal Hdmi Output
HDMI Micro connector (Type D)
Terminal Other
Microphone / shutter release input: 2.5mm
NP-W126S Li-ion battery (included)
Battery Life
For Still Images: Approx. 350 / 420 frames (EVF / OVF Normal Mode)
Actual Battery Life Of Movie Capture
[4K] approx. 45min. (29.97p)
[Full HD] approx. 50min. (59.94p) Continuance Battery Life
Movie Capture: [4K] approx. 50min. (29.97p)
[Full HD] approx. 75min. (59.94p)
Operating Temperature
0 Degree C-+40 Degree C Operating Humidity
10%-80% (no condensation)
Starting Up Period
Approx. 0.5sec.
Dimensions (H x W x D)
74.8 x 128.0 x 53.3mm
(Minimum depth 32.7mm)
Weight
Approx. 478g (including battery and SD memory card) Approx. 428g (excluding battery and SD memory card)
Für besonders interessant/bemerkenswert halte ich das neugerechnete Objektiv, den neuen Sucher (scheint der gleiche wie derjenige der X-Pro3 zu sein) und den eingebauten 4 stop ND Filter (X100F hatte nur 3), das Klappdisplay und die deutlich bessere Videofunktionalität.
Damit wird sie immer mehr zur "Allroundkamera" und hat hier einen Vorteil ggü. der Ricoh GRIII als Alternative.
Sie wird aber angeblich keinen Wasserschutz haben und keinen Antishake.
Es gibt auch schon ein Bild im Netz:
Quelle:
Was haltet ihr von diesem Nachfolger? Kennt jemand schon den Preis?
Hier ist schon das Prospekt der Fuji X100V (japanisch), aber mit schönen Bildern als PDF zum Anschauen.
Der Live Stream beginnt bei uns im Forum um 21 Uhr deutsche Zeit, damit Ihr hier auch parallel chatten könnt.
ok, erst mal die Vorstellung von 2 Mittelformatobjektiven. Das GF80/1.7 und GF 30/3.5.
GF80/1.7 unter 800g und 20% kleiner als das 110/2.0
Das GF30/3.5 ist vor allem auf Bildqualität getrimmt. Sehr schneller AF.
Roadmap Objektive.
XF50/1.0.
Grosses Front element plus 2 Ed Linsen. Ermöglicht extrem gutes Bokeh. Auch AF sehr gut durch neue Focusing Group nahe am Bajonett. Funktionierender Prototyp wird mit AF vorgeführt. Sieht sehr schnell aus. Kontrast AF.
35 Objektive für X mount. PLus weitere 3 Objektive, die noch unbekannt sind, innerhalb der nächsten 3 Monate.
Jetzt kommt X100...
Seit 9 Jahren die gleiche "Seele" bei allen X100 Modelle (vom Aussehen her). In jeder Generation.
Innerlich änderte sich aber viel (von 12MP bis hoch zu 24MP)
Motto "unchanged & changed"
  • Neues Objektiv (2 aspherische Linsen in der MItte, dadurch noch schärfer/höhere Ausflösungsvermögen), aber Grösse fast identisch zum alten Objektiv in den früheren X100 Modellen. Glaselement optimiert für den Sensor (wider Angle of Incident von 20Grad ->30 Grad). Licht kann besser eingefangen werden. Bildbeispel mit grossem Unterschied zwischen alt & neu.
  • Neuer Sensor
  • Neuer Sucher (3.69 m dots OLED, höherer Kontrast 1:5000, sRGB 97%, heller mit 1500cd, frame rate von 100fps)
  • Klappdisplay (bündig am Body anliegend, kaum merkbar als Klappdisplay)
  • Weather resistant (!) - man muss aber dafür einen Filter auf das Objektiv schrauben (mit einem Adapter)
  • Neue Knöpfe (ISO aber Einstellung anders)
  • Filmsimulationen
  • Video
Es wird noch über die Materialien gesprochen und gezeigt, wie flach wirklich die Rückseite ist trotz Klappdisplay. Ist wirklich eine Ebene.
Jetzt nehmen die 3 eingeladenen Gäste die X100V in die Hand und bringen Kommentare...
Das war's...
Ich muss sagen, ich bin beeindruckt. Fuji hat es wirklich mit diesem Modell geschafft, so ziemlich alles, was sich dei user bisher an Verbesserungen gewünscht ahben, in der X100V umzusetzen.
Bis auf IBIS. Aber IBIS würde vermutlich das Gehäuse so gross machen, dass es eben keine typische X100 mehr wäre. Dann verzichte ich auch lieber auf IBIS.
Tja, das wird jetzt schwierig einer X100V zu wiederstehen... :(
