Minolta dynax 9 built in flash problem.
pityacka
Start again, having initially posted this in the DSLR section(now removed)
Has anyone any idea why, when the built in flash is raised on Dynax 9, it locks the camera ? Lowering the flash, and leaving it down, then switching the camera off, then switching back on, the camera will work normally so long as the flash is left down. With an external flashgun fitted there is no problem whatsoever.
Is this a fault which will need professional repair, or is it some small matter connected with custom functions(for example), etc.?
I have seen a Dynax 9 for sale at a very cheap price, and wondered if it might be worth pursuing if the problem/fault is very minor.
