OM 55mm 1.2 Zuiko pictures
J Watanabe
26 Aug 2009
Here are some pictures taken with my OM4Ti, using the 55mm 1.2 Zuiko lens.
All pictures were taken using Fuji Neopan 400 (developed in ID11), 1/2000th @ F1.2
!!! Bilder bitte nur direkt hochladen !!!
Hi Jeff,
these photos do have their own charme. But for this kind of pictures you should use the 2/90mm. What kind of plant is it? Looks a little bit like cannabis. :z04_5769:
Uli
Not sure of the name in English, but it's not cannabis. It's a type of tree which is common in the mountains here, and which turns a bright red in the fall.
I wanted to try the 55/1.2 for these pictures because I wanted to see what effect using such a fast lens would have. I have a 90/2 macro (which is probably the sharpest lens I have ever used), though I use it more for candid photography than for macro.
Here are a couple photographs shot with the 90/2 macro lens:
Kids at play
Small shrine by pond
Wonderfull pictures! Thank you for showing!
Greetings
Herbert
