Chuck Westfall (Canon-Tech
Chuck Westfall (Canon-Techniker) hat es im Forum von Rob Galbraith mal geschrieben.
Kompatible Objektive für E-TTL II, welche die Entfernungsinformation liefern:
http://www.robgalbraith.com/ubbthreads/showflat.php?Cat=&Board=UBB18&Number=217765&Forum=f18&Words=24-70&Searchpage=0&Limit=50&Main=215491&Search=true &where=bodysub&Name=210&daterange=0&newerval=&newertype=&olderval=&oldertype=&bodyprev=#Post217765"
As promised, here is the updated list of Canon EF lenses that supply distance data to the EOS-1D Mark II for use with E-TTL II:
Lens Distance Information
EF14mm f/2.8L USM
EF20mm f/2.8 USM
EF24mm f/1.4L USM
EF28mm f/1.8 USM
EF35mm f/1.4L USM
MP-E65mm f/2.8 1-5x Macrophoto
EF85mm f/1.8 USM
EF100mm f/2 USM
EF100mm f/2.8 Macro USM
EF100mm f/2.8 Macro*
EF135mm f/2L USM
EF180mm f/3.5L Macro USM
EF200mm f/2.8L II USM
EF200mm f/2.8L USM*
EF300mm f/2.8L IS USM
EF300mm f/4L IS USM
EF300mm f/4L USM*
EF400mm f/2.8L IS USM
EF400mm f/4 DO IS USM
EF400mm f/5.6L USM
EF500mm f/4L IS USM
EF600mm f/4L IS USM
EF1200mm f/5.6L USM
EF16-35mm f/2.8L USM
EF17-35mm f/2.8L USM*
EF17-40mm f/4L USM
EF20-35mm f/3.5-4.5 USM
EF24-70mm f/2.8L USM
EF24-85mm f/3.5-4.5 USM
EF28-70mm f/2.8L USM*
EF28-80mm f/3.5-5.6 USM*
EF28-105mm f/3.5-4.5 II USM
EF28-105mm f/3.5-4.5 USM*
EF28-105mm f/4-5.6 USM
EF28-105mm f/4-5.6
EF28-200mm f/3.5-5.6 USM
EF28-200mm f/3.5-5.6*
EF28-300mm f/3.5-5.6L IS USM
EF35-135mm f/4-5.6 USM*
EF70-200mm f/2.8L IS USM
EF70-200mm f/2.8L USM
EF70-200mm f/4L USM
EF70-210mm f/3.5-4.5 USM*
EF70-300mm f/4.5-5.6 DO IS USM
EF90-300mm f/4.5-5.6 USM
EF100-300mm f/4.5-5.6 USM
EF100-400mm f/4.5-5.6L IS USM
EF-S18-55mm f/3.5-5.6 USM
*Indicates discontinued product
If your Canon EF lens doesn't show up on this list, it does not feed distance data back to the camera through the electronic mount.
As a reminder, distance data is never the only factor that controls flash exposure in E-TTL II. It is an optional data point, no more and no less. E-TTL II remains functional with *all* Canon EF lenses, but when using direct flash, E-TTL II is at its best when distance data is available.
Chuck Westfall
Director/Technical Marketing Dept.
Camera Division/Canon U.S.A., Inc.
