- 15 Mai 2002
Sigma hat heute seine erste spiegellose Kamera mit elektronischem Sucher und Sigma SA Bajonett angekündigt. Es gibt sogar zwei davon. Sie heissen Sigma SD Quattro und Sigma SD Quattro H, je nach Sensorgrösse.
Eine extra Webseite hat Sigma dafür auch kreiert:
http://www.sigma-global.com/en/cameras/sd-series/specifications/
Die Spezifikationen:
Format
Format Interchangeable-Lens Digital Camera
Compatible Lenses SIGMA SA mount interchangeable lenses
Lens Mount SIGMA SA bayonet mount
Angle of View Equivalent to approx. 1.5 times the focal length of the lens (on 35mm cameras) Equivalent to approx. 1.3 times the focal length of the lens (on 35mm cameras)
Image Sensor
Image Sensor Foveon X3 direct image sensor(CMOS)
Image Sensor Size 23.5×15.5mm (0.9 inch×0.6inch) 26.6×17.9mm (1.0 inch×0.7 inch)
Number of Pixels Effective Pixels: Approx. 29MP
T(Top): 5,424×3,616 / M(Middle): 2,720×1,808 / B(Bottom): 2,720×1,808
Total Pixels: Approx. 33MP Effective Pixels: Approx. 44.8MP T(Top): 6,200×4,152 / M(Middle): 3,348×2,232 / B(Bottom): 3,348×2,232
Total Pixels: Approx. 45MP
Aspect Ratio 3:2
Recording System
Storage Media SD Card, SDHC Card, SDXC Card, Eye-Fi Card
File Format Lossless compression RAW data (14-bit), JPEG (Exif2.3), RAW+JPEG
JPEG Image Quality FINE, NORMAL, BASIC
Color Mode 11 types ( Standard, Vivid, Neutral, Portrait, Landscape, Cinema, Sunset Red, Forest Green, FOV Classic Blue, FOV Classic Yellow, Monochrome )
File Size
RAW
HIGH T:5,424×3,616 / M:2,712×1,808 / B:2,712×1,808
LOW T:2,704×1,808 / M:2,704×1,808 / B:2,704×1,808
JPEG
[21:9]
S-HI 7,680×3,296
HIGH 5,424×2,328
LOW 2,704×1,160
S-LO 1,920×816
[16:9]
S-HI 7,680×4,320
HIGH 5,424×3,048
LOW 2,704×1,520
S-LO 1,920×1,080
[3:2]
S-HI 7,680×5,120
HIGH 5,424×3,616
LOW 2,704×1,808
S-LO 1,920×1,280
[4:3]
S-HI 6,816×5,120
HIGH 4,816×3,616
LOW 2,400×1,808
S-LO 1,696×1,280
[7:6]
S-HI 6,352×5,120
HIGH 4,480×3,616
LOW 2,224×1,808
S-LO 1,584×1,280
[1:1]
S-HI 5,120×5,120
HIGH 3,616×3,616
LOW 1,808×1,808
S-LO 1,280×1,280
RAW
HIGH T:6192×4128 / M:3096×2064 / B:3096×2064
LOW T:3088×2056 / M:1544×1028 / B:1544×1028
JPEG
[21:9]
S-HI 8,768×3,752
HIGH 6,192×2,648
LOW 3,088×1,320
S-LO 1,920×816
[16:9]
S-HI 8,768×4,928
HIGH 6,192×3,480
LOW 3,088×1,736
S-LO 1,920×1,080
[3:2]
S-HI 8,768×5,840
HIGH 6,192×4,128
LOW 3,088×2,056
S-LO 1,920×1,280
[4:3]
S-HI 7,792×5,840
HIGH 5,504×4,128
LOW 2,736×2,056
S-LO 1,696×1,280
[7:6]
S-HI 7,296×5,840
HIGH 5,152×4,128
LOW 2,560×2,056
S-LO 1,584×1,280
[1:1]
S-HI 5,840×5,840
HIGH 4,128×4,128
LOW 2,048×2,048
S-LO 1,280×1,280
White Balance
Settings 12 types ( Auto, Auto (Lighting Source Priority), Daylight, Shade, Overcast, Incandescent, Fluorescent, Color Temperature, Flash, Custom 1, Custom 2, Custom 3 )
Viewfinder
Type Electronic viewfinder (approx. 2,360,000 pixels color LCD monitor)
Viewfinder Frame Coverage approx. 100%
Viewfinder Magnification approx. 1.09x (-1m-1, 50mm F1.4 at infinity)
Eye point approx. 21mm (–1m-1)
Diopter Adjustment Range approx. -4m-1 to +2m-1
Autofocus
Auto Focus Type Phase difference detection system + Contrast detection system
AF Point 9 points select mode, Free move mode (It is possible to change the size of Focus Frame to Spot, Regular and Large), Face Detection AF Mode
AF Operating Range EV -1~EV 18 (ISO100 F1.4)
Focus Mode Single AF, Continuous AF (with AF motion prediction function), Manual
Focus Lock AEL/AF lock button is pressed or shutter release button is pressed halfway
Exposure Control
Metering Systems Evaluative Metering, Spot Metering, Center-Weighted Average Metering
Metering Range EV 0~EV 17 (50mm F1.4 ISO100)
Exposure Control System (P) Program AE (Program Shift is possible), (S) Shutter Speed Priority AE, (A) Aperture Priority AE, (M) Manual
ISO Sensitivity ISO 100-6400
Exposure Compensation ±5 EV (in 1/3 stop increments)
AE Lock AEL/AF lock button is pressed or shutter release button is pressed halfway
Auto Bracketing Number of shots: 3, or 5 (Appropriate, under, over; 1/3EV steps up to ±3EV for appropriate exposure)
Shutter
Shutter Type Electronically Controlled Focal Plane Shutter
Shutter Speed 1/4000 - 30 sec., Bulb (With Extended Mode : Max. 2 min.)
External Flash Sync. X-Sync(1/180)
Flash
Connectivity Hot shoe (contact X synchronization at 1/180 sec. or less, with dedicated flash linking contact)
Sync Terminal Available
LCD Monitor
Type TFT color LCD monitor
Monitor Size 3.0"
LCD Pixels Approx. 1,620,000 pixels
Coverage 100%
Electronic Level Display Available
Playback
Reviewing Images Single frame display, 9 frames multi display, Zoom, Slide Show
Highlight Display Available
Histogram Available
Menu
LCD Monitor Language English / Japanese / German / French / Spanish / Italian / Simplified Chinese / Traditional Chinese / Korean / Russian / Dutch / Polish / Portuguese / Danish / Swedish / Norwegian / Finnish
Interfaces
Interfaces USB (USB3.0, micro B), HDMI (Type C mini-pin HDMI connector), Remote
Power Source
Power Li-ion Battery BP-61, Battery Charger BC-61, AC adapter SAC-7 (optional) [DC connector CN-31, AC cable (supplied)]
Dimensions and Weight
Dimensions 147mm/5.79"(W) × 95.1mm /3.74"(H) × 90.8mm/3.57"(D) 147mm/5.79"(W) × 95.1mm /3.74"(H) × 90.8mm/3.57"(D)
Weight 625g / 22oz. (without battery and card) TBD
Operating Environment
Operating Temperature 0 - +40℃
Price
sd Quattro Body -
Accessories
Accessories Li-ion Battery Pack BP-61 / Battery Charger BC-61 / AC Cable of Battery Charger / USB Cable / Strap / Body Cap / Instruction Manual / Limited Warranty / Warranty Sticker
Optional Accessories
Optional Accessories Power Glip PG-41 / AC Adapter SAC-7 / Cable Release Switch CR-31 / Electronic Flash EF-630 / Li-ion Battery BP-61 / Battery Charger BC-61 (AC cable is supplied) / AC adapter SAC-7(optional)[DC connector CN-31, AC cable (supplied)]
Format
Image Sensor
Aspect Ratio 3:2
Recording System
File Size
RAW
JPEG
[21:9]
S-HI 7,680×3,296
HIGH 5,424×2,328
LOW 2,704×1,160
S-LO 1,920×816
[16:9]
S-HI 7,680×4,320
HIGH 5,424×3,048
LOW 2,704×1,520
S-LO 1,920×1,080
[3:2]
S-HI 7,680×5,120
HIGH 5,424×3,616
LOW 2,704×1,808
S-LO 1,920×1,280
[4:3]
S-HI 6,816×5,120
HIGH 4,816×3,616
LOW 2,400×1,808
S-LO 1,696×1,280
[7:6]
S-HI 6,352×5,120
HIGH 4,480×3,616
LOW 2,224×1,808
S-LO 1,584×1,280
[1:1]
S-HI 5,120×5,120
HIGH 3,616×3,616
LOW 1,808×1,808
S-LO 1,280×1,280
RAW
JPEG
[21:9]
S-HI 8,768×3,752
HIGH 6,192×2,648
LOW 3,088×1,320
S-LO 1,920×816
[16:9]
S-HI 8,768×4,928
HIGH 6,192×3,480
LOW 3,088×1,736
S-LO 1,920×1,080
[3:2]
S-HI 8,768×5,840
HIGH 6,192×4,128
LOW 3,088×2,056
S-LO 1,920×1,280
[4:3]
S-HI 7,792×5,840
HIGH 5,504×4,128
LOW 2,736×2,056
S-LO 1,696×1,280
[7:6]
S-HI 7,296×5,840
HIGH 5,152×4,128
LOW 2,560×2,056
S-LO 1,584×1,280
[1:1]
S-HI 5,840×5,840
HIGH 4,128×4,128
LOW 2,048×2,048
S-LO 1,280×1,280
White Balance
Viewfinder
Autofocus
Exposure Control
Shutter
Flash
LCD Monitor
Monitor Size 3.0"
Coverage 100%
Playback
Histogram Available
Menu
Interfaces
Power Source
Price
sd Quattro Body -
Accessories
